How do I keep the attributes from a DXF?
  • Oct 7, 2024 3:24 PM UTC
  • 180 views
ricardohhd
Participant
I have a DXF file that consists of multiple geometries and attributes. I want to convert this DXF file to a file geodatabase with multiple layers based on each geometry type in the DXF. The different layers also need to retain the same attributes as the DXF files. I attached the file as a zip to this post.
I tried loading the DXF file in FME using the Autodesk Autocad DWG/DXF reader and splitting the geometries using a GeometryFilter. That worked fine. However, the attributes disappear when I read the DXF file in FME. Do you have any suggestions on how to retain the attributes of a DXF file when reading it in FME and converting it to a GDB? The data was gathered with a Leica gs18T in case that helps.
thomasmarti
Forum|alt.badge.img+9
  • Oct 7, 2024 7:04 PM UTC
Hi @ricardohhd
unfortunately I can’t read the ZIP-File, the size is only 1kb.
Did you check your settings in the dxd-Reader?
BTW: In the Reader-settings you can read the data by geometry instead of LayerName, so you don’t need a “GeometryFilter”
If you can’t see the attributes you can try to find the with the “AttributeExposer” or you check all the attributes in the reader-transformer-settings
