How can i see materials properties of building element in ArcGIS Pro ttribute? What should i have to do in FME Workbench to add attribute with materials properties?
  • December 20, 2019
  • 5 views
How can i see materials properties of building element in ArcGIS Pro attribute? I did export IFC from Revit and translate it to shapefile but i was not able to see materials properties. So what should i have to do in FME Workbench to add attribute with materials properties?
nampreetatsafe
Forum|alt.badge.img+12
Hi @engineerchirayu: Throwing some ideas... I'm wondering if the material properties you are looking for show up in the Feature Information panel when inspecting your data? If so, see if they are stored in a format attribute, or try using an AttributeExposer.
