Highlight KML Icons using Feature Writer
  • Jul 25, 2018 4:17 PM UTC
  • 75 views
dmerrick
Is it possible to create normal/highlighted KML icons with KML FeatureWriters instead of the standard KML Writer shown in the FME example Here:
I am exporting an entire SDE database to 6 different formats and used FeatureWriters to convert/insert a disclaimer into the zipped datasets.
Thanks!
Hi @dmerrick,
The highlighted KML icons are created using the KMLStyler transformer so I wouldn't expect the results to be any different when written out to a feature writer. Using the template provided I added all the connections to the same port and this worked as it should.
dmerrick
  • Jul 25, 2018 5:28 PM UTC
Hi @dmerrick,
Thanks for the response @hollyatsafe but the FeatureWriter KML does not pick up the attributes from the KML Style. Nor does putting the normal/highlighted KMLStyler inline to the FeatureWriter KML create the hover labelling, it layers to normal/highlighted icons on top of each other.
Hi @dmerrick,
Hi @dmerrick
I received an email with your comment but can't seem to see it so shall repeat below:
I did not encounter either of these issues - which version of FME are you currently using?
In the Feature Writer under make sure the kml_target_style 's created are exposed under the Format Attributes Header (these were already checked automatically for me). I've included a screenshot of the set up below.
dmerrick
  • Jul 25, 2018 6:53 PM UTC
Hi @dmerrick
Thanks @hollyatsafe, I had the KMLStyle's still going to the Style Writer and did not realize you could connect them directly to the FeatureWriter KML (or a previous transformer) and the attribute would get passed through.
