Georeference tif raster using sup file
  • Aug 16, 2019 6:47 AM UTC
  • 58 views
zubairsm
Forum|alt.badge.img+9
Hello friends,
I am stuck at as to how to determine parameters to do a georeference using transformer Rastergeoreference.
Please see attach sup file (renamed it to .txt). What I understood (I maybe wrong) is the parameter LSR_CAMERA is the center point and OPK_LSR is the rotation (3 values in radians ) but I dont know how to convert into degrees ( 1 value). Basically what I need is the following parameter to do a georeference
By Point and Angle
XY Upper Left Coordinate
XY cell spacing
Rotation (Degrees)
Appreciate your help
Forum|alt.badge.img+63
To go from radians to degrees you need to multiply by 180 and then divide through pi
I assume you know where on earth this is supposed to be and what the coordinate system is, usually that can be helpful to determine how to georeference it.
