Geom column in spatial databases
Hello,
I noticed while migrating some Shapefiles to MSSQL Spatial that there's a Geom column which is added. In which format it is encoded ? And does it countain all the spatial data required informations to restore and draw all the stored features ?
thank you
Best answer by david_r
If you look at the table definition in e.g. MS SQL Server Management Studio, you'll most proabably see that the column is of type "geometry", which is the native data type for geometry objects in SQL Server.
More info here:
https://docs.microsoft.com/en-us/sql/t-sql/spatial-geometry/spatial-types-geometry-transact-sql?view=sql-server-2017
If you're using an ArcGIS Geodatabase extension on top of SQL Server, things gets more complicated, see the bottom two paragraphs here:
https://pro.arcgis.com/en/pro-app/help/data/geodatabases/manage-sql-server/sqlserver-spatial-types-and-arcgis.htm
erik_jan
Forum|alt.badge.img+19
  • May 24, 2018
The GEOM column is the default name for the geometry (point, line, area etc) that is stored in a spatial table.
The format it is stored in depends on the spatial database.
You can specify an alternative name for the column in the writer parameters.
  • May 24, 2018
More info here:
More info here:
Thank you for the answer
Is it encoded in WKB in case of MSSQL ?
  • May 24, 2018
The geometry is encoded in a format native to SQL Server, as far as I know.
But you can cast the geom column to OGC WKB if you need, e.g.
select geom.STAsBinary() from my_table
See also: https://docs.microsoft.com/en-us/sql/t-sql/spatial-geometry/stasbinary-geometry-data-type?view=sql-server-2017
