I'm trying to use a gdb file with FME 2013 but am getting this error:
|ERROR |Geodatabase Error (-2147220965): This release of the GeoDatabase is either invalid or out of date.
|ERROR |Could not open File Geodatabase dataset `D:/flood/GDB/uFMfSW_Banded_Vector_SK00.gdb' for reading.
I'm using the "Esri Geodatabase (File Geodatabase API)" reader. I do have ArcGIS 10.1 installed on the same machine, but for some reason FME isn't picking it up so I can't use the ArcObjects one.
How do I read this?
