FME2010 SP4 and ESRI ArcGIS licensing problem
  • Dec 13, 2012 1:13 PM UTC
  • 64 views
Hi, I have runned into some strange behaviour with FME Desktop and ArcGIS.
My ArcGIS licences are 1 ArcInfo, 15 ArcEditor and 15 ArcView hosted on a license server.
Under Citrix I set the variable ESRI_SOFTWARE_CLASS=Viewer as a default environment variable. This works fine, and for example a "double-click" on a MXD icon will launch ArcView. Given this as the default behaviour I provide users with separate startup icons for ArcEditor and ArcInfo (ESRI_SOFTWARE_CLASS=Editor or Professional respectively).
But, when I launch FME and start an ETL-workflow which requires an ArcGIS license, then FME try to launch ArcInfo. Seems like ESRI_SOFTWARE_CLASS=Viewer (i.e ArcView) is not honoured by FME.
The same seems to be the case for local installs. FME honours license settings from the ArcGIS Administrator and not what i set by ESRI_SOFTWARE_CLASS.
Anyone knows a way to force a specific ArcGIS licensetype to be used by FME?
best
Pål Herman
Oslo, Norway
davideagle
Forum|alt.badge.img+21
  • Dec 14, 2012 8:27 AM UTC
Hi Pal - I'm not sure on exactly the issue but as you are using an older version of FME around the time some changes happened with the shipping of DLLs with FME and also given that there are always challenges getting your FME and ESRI versions compatible with each other take a look here http://fmepedia.safe.com/articles/Samples_and_Demos/Notes-on-FME-and-ESRI-Versions-and-Compatibility to make sure your versioning at least ties up to begin with. It might give you a way forward at least...
  • Dec 14, 2012 11:25 AM UTC
Thanks Dave, many thanks for the effort and the link which I had missed. Looking at the info for version compability:
ArcGIS 10.0 and FME2010 SP2 or higher, including FME2011 and FME2012 - Thats exactly my setup (Which is FME2011SP4 and ArcGIS10.0 SP5.
Norwegian ESRI distributor find the same problem, I guess they run ArcGIS10.1 and FME2012 (maybe 2013).
Thanks again, cheers Pål
fmelizard
Forum|alt.badge.img+22
  • Dec 19, 2012 10:01 PM UTC
Hi Pål ,
You can force FME to use a certain Esri edition using a python Startup Script.  The script below should set the correct license level as specified by your ESRI_SOFTWARE_CLASS variable:
import sys,os
try:
    SWClass=os.environ['ESRI_SOFTWARE_CLASS']
    print("Environment variable ESRI_SOFTWARE_CLASS has value: "+SWClass)
    if SWClass=="Viewer":
        import arcview
    elif SWClass=="Editor":
        import arceditor
    elif SWClass=="Professional":
        import arcinfo
    else:
        print("Invalid value found for environment variable ESRI_SOFTWARE_CLASS")
        print("Try changing to \\"Viewer\\", \\"Editor\\", or \\"Professional\\"")
    import arcpy
    print("Esri Edition set to "+ arcpy.ProductInfo())
except:
    print("Environment variable ESRI_SOFTWARE_CLASS is not set")
