FME Workbench to ArcGIS Interoperability/FME Interop...
  • May 30, 2013 4:30 AM UTC
  • 74 views
I have a custom FME toolset that a client would like to run in ArcGIS. If they were to have the FME Data Interoperability extension purchased/enabled is there a way to upload/convert/run a full-suite FME workbench in the ArcGIS/FME Data Interoperability Extension?
If so, how would I proceed? I work in both FME and ArcGIS but have not worked with both in this way before. Any help with this would be appreciated.
Matthew Brucker
  • May 30, 2013 2:47 PM UTC
You have the "FME Integration Console" and the "FME Extension for ArcGIS" in the help which explain the necessary steps.
Good luck
Marc
Hi Matthew,
here is the link to the ArcGIS Help:
http://resources.arcgis.com/en/help/main/10.1/index.html#/Spatial_ETL_tools/004m0000000m000000/
I hope this is a good start and you can go from there,
regards,
Stefan
  • Aug 15, 2013 7:59 AM UTC
Hi Matthew,   I encountered a situation as same as yours. After searching in the Safe site, I found out your question and "FME & Esri ArcGIS Data Interoperability FAQ". For your information.
Takashi
