error ( Microsoft SQL Server Spatial Reader: Failed to connect using Microsoft OLE DB Driver for SQL Server. Provider error '(-2147467259)). FME server version FME Server 2022.2 Build 22765 - win64, works on desktop with same SQLServer credentials
FME SQL Server Reader failing to connect . how do I check if this is a client issue? The DB is 2019 SQLServer.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
