FME cmd.exe display transaction log with timestamps
lucky
I use "LOG_STANDARDOUT Yes" in a batch-command to Display logging of a workbench!
Is it possible to also Display the time like it is the log-file?
  • October 16, 2018
I've never used that option, but have you tried activating the timestamps in the FME log window?
lucky
  • October 16, 2018
yes, it is activated and works fine in workbench but not in command
  • October 16, 2018
Hm, then I've got no idea. Hopefully someone else knows the answer. If not, consider contacting Safe support through your FME reseller.
lucky
  • October 16, 2018
okay, it seemed to be a Problem with user-profiles!
A Restart of my Computer solved the Problem, now I can log the time!
