FME 2021.0.3.2 crashes on macOS 14.6.1
  • September 2, 2024
  • 52 views
skotnicam
Participant
Hello,
I am running on macOS 14.6.1 and I use FME 2021.0.3.2 which stopped working from today. It crashes after “Initializing Main Window”. I am attaching the relevant part (I hope) of the crash report. Has anyone run into the same problem?
(Data inspector and Quick translator work, only Workbench crushes)
Thank you!
Notes:
PC register does not match crashing frame (0x0 vs 0x7FF89317AA78)
Crashed Thread:        0  CrBrowserMain  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Termination Reason:    Namespace SIGNAL, Code 6 Abort trap: 6
Terminating Process:   FME Workbench [1810]
Application Specific Information:
abort() called
Error Formulating Crash Report:
Thread 0 Crashed:: CrBrowserMain Dispatch queue: com.apple.main-thread
0   ???                           	    0x7ff89317aa78 ???
1   libsystem_kernel.dylib        	    0x7ff802e92db6 __pthread_kill + 10
2   libsystem_pthread.dylib       	    0x7ff802ecbebd pthread_kill + 262
3   libsystem_c.dylib             	    0x7ff802df1a79 abort + 126
4   QtCore                        	       0x10ad7f819 0x10ad67000 + 100377
5   QtCore                        	       0x10b0bee4e QMessageLogger::fatal(char const*, ...) const + 196
6   QtCore                        	       0x10b0be5d4 qt_assert_x(char const*, char const*, char const*, int) + 74
7   libfmeuiparammodel.dylib      	       0x11211b003 ui::param::model::FormatUtil::addCustomFormats(QStringList&, QStringList&, QHash<QString, QHash<QString, QString>>&) (.cold.10) + 35
8   libfmeuiparammodel.dylib      	       0x1120b1717 ui::param::model::FormatUtil::addCustomFormats(QStringList&, QStringList&, QHash<QString, QHash<QString, QString>>&) + 3639
9   libfmeuiparammodel.dylib      	       0x1120b08bd ui::param::model::FormatUtil::loadFormats() const + 173
10  FME Workbench                 	       0x100546be0 QFMETransformerListModel::rebuild() + 1504
11  FME Workbench                 	       0x100547eed QFMETransformerListModel::QFMETransformerListModel(QObject*) + 45
12  FME Workbench                 	       0x10052dd6c QFMEQuickSearch::QFMEQuickSearch(QWidget*) + 396
13  FME Workbench                 	       0x1006328aa WBCanvas::WBCanvas(WBDoc*, QWidget*) + 186
14  FME Workbench                 	       0x100605236 CVFmeSuperView::createView(WBDoc*) + 182
15  FME Workbench                 	       0x100604a2e CVFmeSuperView::showDocument(WBDoc*) + 206
16  FME Workbench                 	       0x100604838 CVFmeSuperView::showEvent(QShowEvent*) + 56
17  QtWidgets                     	       0x10c9118ac QWidget::event(QEvent*) + 1164
18  QtWidgets                     	       0x10c8d7fd6 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 262
19  QtWidgets                     	       0x10c8d93a2 QApplication::notify(QObject*, QEvent*) + 466
20  QtCore                        	       0x10af58424 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 212
21  QtWidgets                     	       0x10c91061a QWidgetPrivate::show_helper() + 426
22  QtWidgets                     	       0x10c9112a4 QWidgetPrivate::setVisible(bool) + 868
23  QtWidgets                     	       0x10c91087e QWidgetPrivate::showChildren(bool) + 398
24  QtWidgets                     	       0x10c9104b8 QWidgetPrivate::show_helper() + 72
25  QtWidgets                     	       0x10c9112a4 QWidgetPrivate::setVisible(bool) + 868
26  libqfmeext.dylib              	       0x110fca59d QFMEShowMainWindow(long, bool, QMainWindow*) + 29
27  FME Workbench                 	       0x100617466 WBApp::initialize() + 9270
28  FME Workbench                 	       0x100364ce5 main + 101
29  dyld                          	       0x201129345 start + 1909
emma.at.safe
Forum|alt.badge.img+8
Hey @skotnicam,
Our team has received your support ticket and a response has been sent out.
The crashing behavior you encountered with FME Workbench 2021.0.3.2 on macOS 14.6.1 is likely due to compatibility issues, as FME 2021.0.x is only supported on macOS 10.15 and 11. FME versions that are supported on macOS 14 start from FME 2023.x and newer.
To resolve the issue, you can either:
  1. Upgrade to FME 2023.x or newer on your macOS 14 machine (recommended).
  2. Downgrade your macOS to 10.15 or 11 and continue using FME Workbench 2021.0.3.2.
Hope that helps!
-Emma
