FME 2017 crashes with 2 dynamic realdwg writers
zzupljanin
Forum|alt.badge.img+4
so my FME 2017.1 (32 or 64 bit) crashes when trying to save workspace. Bizarre, right.
Anyway, here are some pics for info. Hopefully this will help. I can't post workspace since it crashes.
Cheers,
Zelimir
sigtill
Forum|alt.badge.img+24
  • November 18, 2019
Hi @zzupljanin
I would recommend to install newest FME and try there, it can easily be installed on the same computer as FME2017, just change the install directory: https://www.safe.com/support/downloads/
It might be that the two DWG-writers are:
1. Using the same template - try to copy the template to a new files so they dont try to open the same template file
2. Write to the same folder/file - try to change the output-folder to another folder just to make sure they are not writing to the same file.
Forum|alt.badge.img+19
  • November 18, 2019
Hi @zzupljanin, this article might help you if FME is running with Windows 7 machine.
Workbench Crashes (Windows 7 with Intel or AMD Graphics Card)
