Filter out shapes and cells in dgn file
  • Sep 19, 2013 7:29 PM UTC
  • 43 views
I'm using FME Desktop 2013.  I'd like to know if there is a way to filter/separate out "shapes" and "cells" that are on the same level in the dgn file.
Thank you
dustin
Forum|alt.badge.img+36
  • Sep 19, 2013 8:15 PM UTC
You should be able to use the AttributeExposer to expose the igds_cell attributes.
fmelizard
Forum|alt.badge.img+22
  • Sep 20, 2013 1:28 PM UTC
You can expose the igds_type and test for igds_cell and igds_shape.
Itay
  • Sep 23, 2013 6:54 PM UTC
Thank you for the responses.  Exposing igds_cell_name using AttributeExposer did the trick!
