File Properties, change created and modified by date
  • Mar 27, 2017 6:10 PM UTC
  • 178 views
hlouie
Forum|alt.badge.img+17
I have a directory of PDF files scanned in 1996, I have feature dataset linked by PDF filename the with another attribute field with correct document creation date.
How can change the PDF filename properties of creation data?
erik_jan
Forum|alt.badge.img+26
  • Mar 27, 2017 6:27 PM UTC
FME does not have a PDF reader. So the contents can not be changed.
But if you need to copy (or move) all files to a different file name you can use:
Read the filenames using the "Directory and File path" reader.
The "File copy" writer to copy or move the files to a different location and/or name.
hlouie
  • Mar 27, 2017 8:37 PM UTC
Using the File Copy, creates a new file and changes the date/time to current. It's not just PDF but any file (text, dwg, tiff) changing the created/modified date.
hlouie
  • Mar 27, 2017 10:07 PM UTC
Workbench
DateFormatter = 2018-01-01 to destination Epoch date %s
Python Caller = os.utime( filename , (convert Epoch date string to int, convert Epoch date string to int)
import fme
import fmeobjects
import os
def FeatureProcessor(feature):
    os.utime(feature.getAttribute('file'), (int(feature.getAttribute('date')),int(feature.getAttribute('date'))))
