[Feature Reader] error opening path reader on URL
  • Dec 17, 2017 8:16 PM UTC
  • 57 views
Best answer by takashi
Hi @sobanmughal, I don't think the PATH reader supports reading properties of the files saved in a Web server disk system. If you have privilege to access the directory with FTP protocol, you can create a Python script with the "ftplib" module to retrieve file properties in the directory. See here to learn about the module: ftplib -- FTP protocol client, Python Documentation
I am trying to use Feature Reader to extract file properties like path_modified_date for a file store on http folder e.g http://xyz.net/abc.csv
I am getting the following error.
"Opening the PATH Reader on folder http://xyz.net/. Could not find folder"
danilo_fme
Forum|alt.badge.img+58
  • Dec 17, 2017 11:17 PM UTC
Hi @sobanmughal,
I copy and paste your address in browser and a error was happened:
Is correct this link?
Thanks,
Danilo
  • Dec 18, 2017 12:17 AM UTC
Hi @sobanmughal,
Thanks,
Danilo
the link supplied is not real and only given as an example. The real link is internal and is not shared.
  • Dec 18, 2017 5:07 AM UTC
