In MS Access database, the Occurrence table has an XML data type field called “ReportDataXML”. This field contains details/values for all the fields on a particular form for a given record.
I need this field transposed to a table for each record in the Occurrence table. The transposed table should have columns for record id and the xml values for each node – see second table for an example of what I’m after.
Source data sample – record id = 6, ReportDataXML field extract only for 3 fields.
Occurrence table ID field has value:
6
ReportDataXml field has the following content (exerpt only):
<F7183047af02945f1aa4cf819519c1b72 xmlns="http://www.gaelquality.com/Bacchus/OccurrenceFields" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<DataType>list-reference</DataType>
<Value>3193</Value>
<Archived>false</Archived>
</F7183047af02945f1aa4cf819519c1b72>
<Fa080141ebf5b417999a0b5da90569306 xmlns="http://www.gaelquality.com/Bacchus/OccurrenceFields" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<DataType>string</DataType>
<Value>Garry Capp</Value>
</Fa080141ebf5b417999a0b5da90569306>
<F824a8279f81a4eeaba0e3b6ac62bbccd xmlns="http://www.gaelquality.com/Bacchus/OccurrenceFields" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<Value>The employee, received an injury to their shoulder and neck whilst using a crowbar to remove rocks & concrete.
INC allocated to wrong work area. Found INC report and attached relevant docs that actions had been completed. S Gueth</Value>
</F824a8279f81a4eeaba0e3b6ac62bbccd>
Expected output from transpose would be:
ID
UIElement
DataType
Value
Archived
6
list-reference
3193
FALSE
6
string
Garry Capp
FALSE
6
string
FALSE
Could you please guide me with the steps please?
