ExcelStyler first row no colour
  • Jul 1, 2020 3:33 PM UTC
  • 13 replies
  • 151 views
connecter
Forum|alt.badge.img+10
Hello,
my problem is to style a simple Excel table.
When cell xy is 1 --> colour background set to red.
It is working in many cases only the first row doesn't turn red. What am I doing wrong?
Result in Excel:
Thanks for your help. :)
Forum|alt.badge.img+54
  • Jul 1, 2020 3:43 PM UTC
Can you share your conditional statement for the background colour?
danilo_fme
Forum|alt.badge.img+58
  • Jul 1, 2020 3:45 PM UTC
Hi @connecter
Could you share your Workspace?
Whats version of FME are you using?
I tested here:
Thanks in Advance,
Danilo
danilo_fme
  • Jul 1, 2020 3:46 PM UTC
Hi @connecter
I tested here:
Thanks in Advance,
Danilo
The condition on ExcelStyler:
connecter
  • Jul 1, 2020 3:59 PM UTC
Hi Danilo,
thanks for your fast response. I don't understand it where my mistake is... :(
My version is: 2020.0.1.0 (20200407 - Build 20218 - WIN64)
You find the workflow below. Thanks!
Excel_Farbgebung.fmw
danilo_fme
  • Jul 1, 2020 4:15 PM UTC
Hi Danilo,
Thanks your Workspace.
I opened and removed the Writer and inserted a new one:
Could you test with the attached Workspace?
Thanks in Advance - 39160-excel-farbgebung_New.fmw
Danilo
connecter
  • Jul 1, 2020 4:25 PM UTC
Danilo
Thanks, it is working, but why? I don't see a differense. I also have the same problem at another workflow.
danilo_fme
  • Jul 1, 2020 5:16 PM UTC
Nice - great news :) Thanks your feedback.
I dont know the reason - maybe any dll with different version.
connecter
  • Jul 1, 2020 6:03 PM UTC
I test it futher. With the Inspector everything is working, but without the same problem happens. Then I downloaded the new version (2020.0.3-b20252) and everything is fine. Thanks for your support!
danilo_fme
  • Jul 1, 2020 6:05 PM UTC
Awesome. I'm happy to help you!
connecter
  • Jul 6, 2020 12:52 PM UTC
After moving on, I got the problem back. I think it's a bug. @safesoftware can you look into it?
andreaatsafe
Forum|alt.badge.img+17
Hi @connecter,
I was only able to reproduce this issue with FME build 20218 when the workspace was not saved. I also tested the latest FME 2020.1 version (build 20594) with an unsaved workspace and was not able to reproduce the issue.
With build 20218, after I saved the workspace and re-ran the workspace to a new Excel sheet, the first cell was coloured as expected.
Could you confirm what version (including the build) of FME you are using? If you are using a workspace that was initially created in build 20218 but are using a newer version of FME, could you ensure you update your writer so that the version is updated or add a brand new writer to your workspace?
- Andrea
connecter
  • Jul 10, 2020 7:01 AM UTC
Hi @connecter,
- Andrea
Hi @andreaatsafe,
thanks for testing and your answer. I install the beta (FME(R) 2020.1.0.0 (20200626 - Build 20588 - WIN64)) and everything is fine. In Version 2020 (FME(R) 2020.0.3.0 (20200605 - Build 20252 - WIN64)) the problem pops up sometimes. I delete the write and at a new one. Here are my testresults:
  • When you duplicate the Excelwrite and split the sheets by a column on some pages (sheets/Tabelle see screenshot below) the first row isn't coloured
  • The Inspector has an effect on the output (C= first row coloured, NC = no colour):
  • No Inspector:
    • Tabelle 1: C
    • 2: C
    • 3: C
    • 4: C
    • 5: NC
    • 6: C
    • 7: C
  • One Inspector:
    • Tabelle 1: C
    • 2: C
    • 3: C
    • 4: NC
    • 5: NC
    • 6: NC
    • 7: C
  • Two Inspectors:
    • Tabelle 1: C
    • 2: C
    • 3: NC
    • 4: NC
    • 5: NC
    • 6: NC
    • 7: NC
I don't change anything expect the Inspector(s). I saved the workflow every time before I rerun the workflow and I delete the existed Excelsheet.
I can't share the new workflow- sorry. :(
But it looks like you change the Excelwriting in the new beta, so I go with the beta until it is release as stable version.
andreaatsafe
Hi @andreaatsafe,
  • No Inspector:
    • Tabelle 1: C
    • 2: C
    • 3: C
    • 4: C
    • 5: NC
    • 6: C
    • 7: C
  • One Inspector:
    • Tabelle 1: C
    • 2: C
    • 3: C
    • 4: NC
    • 5: NC
    • 6: NC
    • 7: C
  • Two Inspectors:
    • Tabelle 1: C
    • 2: C
    • 3: NC
    • 4: NC
    • 5: NC
    • 6: NC
    • 7: NC
Hi @connecter,
Thanks for letting me know that one of the 2020.1 betas is working for you.
Apologies I was not clearer in my earlier message, but you can now upgrade to the officially released version of FME 2020.1 build 20594 here: https://www.safe.com/support/downloads/
- Andrea
