Excel problem
  • Apr 11, 2014 7:57 AM UTC
  • 11 replies
  • 115 views
I have a table in Excel as in Fig. how to arrayed all numbers in the second row?
gio
Forum|alt.badge.img+15
  • Apr 11, 2014 8:04 AM UTC
Do you want all numbers to be in the second row or in Row2?
- In second row would be a value issue: u can use a unconditional merger.
- In Row2 would be an attribute issue: a attributecreator can do that.
  • Apr 11, 2014 8:25 AM UTC
in row2..i use attribute creator but nothing happend..
gio
  • Apr 11, 2014 10:38 AM UTC
If u mean to collapse all values to Row2:
try this
gio
  • Apr 11, 2014 10:41 AM UTC
"rij2" is Dutch for row2 btw.
  • Apr 11, 2014 10:52 AM UTC
I'm sorry, I thought like this
  • Apr 11, 2014 10:59 AM UTC
Is this an issue of renaming attributes? If so, I would use the BulkAttributeRenamer.
The BulkAttributeRenamer with this setting renames all "Row**" to "Row2".
Just be aware that "String" parameter must be a constant "Row2". It should not be an Attribute Value.
Takashi
  • Apr 11, 2014 11:23 AM UTC
hi,
tnx for the help,  I dont have new FME, only FME 2012, and I tried it with a string replacer and does not work. have any oder idea?
  • Apr 11, 2014 11:44 AM UTC
How about scripting? For example, the TCLCaller with this script performs the processing similar to the BulkAttributeRenamer.
proc renameRows {} {
    foreach name [FME_AttributeNames] {
        if {[regexp {^Row.+$} $name]} {
            FME_RenameAttribute "Row2" $name
Enter the script into "Source Code" and type "renameRows" (name of the procedure) in "Tcl Expression" parameter.
  • Apr 11, 2014 12:00 PM UTC
woow, it works great..tnx
  • Apr 11, 2014 10:21 PM UTC
Maybe I misunderstood your question. You are trying to accumulate all rows into one row?
A possible way is:
1) Remove all empty attributes. I would use TCLCaller with this script.
proc removeEmptyAttributes {} {
        if {[string compare [FME_GetAttribute $name] {}] == 0} {
            FME_UnsetAttributes $name
2) Accumulate all rows into one row using the AttributeAccumulator.
In FME 2014, the Excel reader (Read blank cells as: Missing) and the Aggregator (Mode: Attributes Only) do it.
  • Apr 11, 2014 10:33 PM UTC
Ah, the Excel reader in FME 2012 seems to read blank cells as missing attributes. So you don't need to remove them explicitly. Just apply the AttributeAccumulator.
