ESRI support on FME Cloud?
  • Apr 28, 2017 4:49 PM UTC
  • 7 replies
  • 127 views
fmelizard
Forum|alt.badge.img+22
A customer has FME Cloud. But now they need to write to GDB (ArcObjects) for raster writing.How should we add ESRI support?
Best answer by gerhardatsafe
Currently on FME Cloud only the Esri Geodatabase (File Geodatabase Open API) is supported. The reason for this is that the Esri Geodatabase (File Geodb) format would require an installation of ESRI software on the same machine which is not supported for several reasons (OS is Linux & there is no access to the machine itself). Even SDE legacy (which will be deprecated by ESRI soon) can not be supported as we can not install the library on the instance.
erik_jan
Forum|alt.badge.img+26
  • Apr 28, 2017 5:06 PM UTC
Clear answer, Gerhard
bruceharold
Forum|alt.badge.img+20
  • Apr 28, 2017 5:50 PM UTC
Is Geopackage Tiles a way through?
  • Feb 13, 2020 9:22 AM UTC
Hi @gerhardatsafe, I have similar situation with FME Cloud, but with writing to Esri Enterprise Geodatabase (SDE) . Is there a work around or a similar reader and writer I can use. Is there a way to load the data into the PostGIS DB in FME cloud and and then migrate that to the Esri Enterprise Geodatabase (SDE). Thanks, Ariam
As you can see here (https://www.safe.com/integrate/arcsde-geodatabase/) the format you are looking for is not supported on FME Cloud. Unfortunately, there is currently no workaround for this limitation. You can only read & write from & to this format on Windows operating systems with ESRI software installed on the same machine.
runneals
Forum|alt.badge.img+32
  • Apr 8, 2020 8:05 PM UTC
Hi @gerhardatsafe couldn't it technically be supported? https://support.esri.com/en/technical-article/000012501 I was thinking that the sde readers/writers use ArcPy (unless I'm completely off, which is pretty likely :P
You would still need to install ArcGIS Server on the same machine even if you use the version that can be executed with a Python 3.x runtime that is installed independently of ArcGIS Server.
More details here:
https://enterprise.arcgis.com/en/server/latest/administer/linux/linux-python.htm
https://anaconda.org/esri/arcgis-server-py3
So still no support on FME Cloud.
On your own Linux with ArcGIS Server installed it would work. But I don't know ArcPy good enough to say whether it would allow you to read/write to Esri Enterprise Geodatabase (SDE).
