Error Building Mosaic from TIFF files
  • December 12, 2020
  • 85 views
rudy_v
I am trying to build a mosaic from 400GB of TIFF files - but is continuous fail
Diskspace Available 4TB - FME Temp file 1TB
Has anyone come across this error - can it that the TIFF is corrupted?
445 2020-12-12 14:18:51 | JPEG2000 writer: Completed 21.76% of intermediate processing
446 2020-12-12 14:19:13 | TIFF reader: LZWDecode:Wrong length of decoded string: data probably corrupted at scanline 27520
447 2020-12-12 14:19:13 | TIFF reader: TIFFReadEncodedTile() failed.
448 2020-12-12 14:19:13 | TIFF reader: \\\\mcc\\gis\\SourceImagery\\Taylors\\2020-10-30_Deliverable\\OrthoImage\\B4.tif, band 1: IReadBlock failed at X offset 215, Y offset 228: TIFFReadEncodedTile() failed.
449 2020-12-12 14:19:13 | TIFF reader: Failed to retrieve data from the source dataset
450 2020-12-12 14:19:13 | JPEG2000 writer: Could not perform Read/Write on file
451 2020-12-12 14:19:13 | JPEG2000 writer: Failed to write dataset '\\\\mcc\\groups\\proptest\\Aerial\\Taylors_October2020_2cm_GDA2020z55.jp2'. This may occur if you have insufficient privileges to write this file, or if insufficient disk space is available
452 2020-12-12 14:19:17 | JPEG2000 writer: A fatal error has occurred. Check the logfile above for details
453 2020-12-12 14:19:19 | ... Last line repeated 2 times ...
454 2020-12-12 14:19:19 | RasterMosaicker (RasterMosaicFactory): Failed to output the feature with the mosaicked raster
455 2020-12-12 14:19:19 | RasterMosaicker (RasterMosaicFactory): A fatal error has occurred. Check the logfile above for details
caracadrian
Forum|alt.badge.img+23
  • December 14, 2020
You need a bigger fme_temp folder and, probably, more RAM
