Dynamic Writer - no output when run from FME Server 2013 sp2 3499
Hi
I have an issue with using the Dynamic writer in FME Server 2013. It produces the zip file but its empty and the location is has written to on disc is also empty. When running the workbench it works but not when uploaded to server 2013.
I had no issue with the dynamic writer on 2012, is there a setting that i have missed out? Even the standard ''easytranslator'' does not produce and files so something to do wth the writer rather then the individual workbench
Regards
fmelizard
Forum|alt.badge.img+19
  • August 2, 2013
Hi there
This sounds like it might be this issue:
http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/Data-Download-Zip-File-Empty
Please let us know one way or the other
Thanks
Ken
  • August 5, 2013
I have specified the desired output writer but im using a generic writer and reader...could this be the issue?
