DWG in GEOTIFF/TIFF
  • Jan 18, 2018 2:05 PM UTC
  • 8 replies
  • 105 views
Hello, I have DWG file and I was wondering if I can somehow transform it to a GeoTIFF or just TIFF? Thank You in advance
  • Jan 18, 2018 2:09 PM UTC
Yes, you can e.g. use the ImageRasterizer between a DWG reader and a GeoTIFF writer.
There's also the MapnikRasterizer if you need more fine-grained control on the result.
I have tried like this but it doesn't work. It gives me an error always.
  • Jan 18, 2018 2:16 PM UTC
And what's the error message?
GEOTIFF writer: Failed to obtain raster from feature. Only features with raster geometry are expected
... Last line repeated 2 times ...
ImageRasterizer: Failed to evaluate expression 'C:\\Users\\Dejan\\Desktop\\11.Plan parcelacije IND 2.dwg'. Result is set to null.
  • Jan 18, 2018 2:29 PM UTC
You shouldn't connect the <Rejected> port to the GeoTIFF writter, it will output the original (vector) features and not a raster.
However, you should post the error messag generated from one of the rejected features here. They're a sign that something is wrong, perhaps in how the ImageRasterizer has been configured.
I am trying now with MapnikRasterizer but I am not sure if it will work.
  • Jan 18, 2018 3:14 PM UTC
Hi @maliodpalube, I'm afraid that you have set a wrong attribute to a parameter in the ImageRasterizer. Connect a Logger or Inspector to the Rejected port and run, then check how the fme_rejection_code attribute says.
gio
Forum|alt.badge.img+15
  • Jan 19, 2018 4:39 PM UTC
@maliodpalube
did you add a feature color to the objects. prior to imagerasterizer?
I don't see it in your workspace. Use featurecolorsetter and set to the autocad color ( you can expose this on the autocad reader, use aply to all unless you like to click a lot..;))
Features without an fme_color attribute will be discarded.
