DWG BIM to GIS
  • Mar 25, 2017 5:21 PM UTC
  • 7 replies
  • 97 views
I want some help in the right direction with converting a DWG BIM 3D file to a DWG 3D CAD/GIS format.
I cannot figure out how to simpoify the 3D-model so that only the outer lines of the 3D model remains
I want it to look like the blue line in the attached picture.
Best Regards,
Jonas
  • Mar 28, 2017 9:23 PM UTC
Hi again,
Here is the code that I figured out so far.
But the lines is in the middle and not outside and it is very slow! It takes many days if I run with all the object as input...
Please help!
Best regards,
Jonas
bim-2-cad-5.fmw
  • Mar 28, 2017 9:28 PM UTC
Heres the FME-code...
/Jonas
mygis
Forum|alt.badge.img+14
  • Jun 27, 2017 10:19 AM UTC
Hi @bigjonas69 ,
Is you workspace doing the process up to your expectations?
lars_de_vries
Forum|alt.badge.img+10
Hi @bigjonas69,
If I understand your question correctly, the solution might be much simpler. When you place a combination of a SurfaceFootprintReplacer, a HullAccumulator and a DonutHoleExtractor after the GeometryFilter, you'll get exactly a polygon that represents the blue line in your first screendump.
I have set the HullAccumulator to "Hull Type: Concave )(" and "Alpha Value: 0.01". This will take some time, but delivers the output you desire. Also you should set the Group By to fme_feature_type if you want to distinct between the two DWG layers that are enabled in your workspace.
If you do not want a polygon, but a polyline, you could use a GeometryCoercer to do so.
  • Sep 16, 2017 3:40 PM UTC
Hi @bigjonas69, I think you can use the Dissolver to merge footprint polygons for each layer. However, depending on the data condition (slight gaps within a tolerance), a preprocess to perform snapping segments could be required.
In addition, after the Dissolver, additional transformers such as Generalizer (Douglas algorithm) and SpikeRemover might be helpful to clean the geometries.
  • Sep 16, 2017 6:05 PM UTC
Hi @bigjonas69,
It worked after I only took one layer.
Group by have also worked.
Thanks!
Sincerely,
Jonas
  • Sep 16, 2017 6:06 PM UTC
Okay, thank you for the tips and trix...
Sincerely,
Jonas
