DuckDB Summarize command
  • November 2, 2024
  • 80 views
oliver.morris
Forum|alt.badge.img+12
I am trying to use the duckdb summarize command
https://duckdb.org/docs/archive/0.9/guides/meta/summarize
in an in memory duckdb using the sqlexecutor:
SUMMARIZE SELECT * FROM read_parquet('/Users/x/Downloads/Address.parquet');
This doesn’t return any results/attributes but ‘runs’ successfully in FME. In DBeaver it runs no issues.
Any idea is there is a trick to get this working?
Many ThanksQ!
Best answer by arnold_bijlsma
@oliver.morris : There is a very simple workaround: wrap the SUMMARIZE or DESCRIBE query in another SELECT * FROM clause:
SELECT * FROM (SUMMARIZE SELECT * FROM read_csv('https://oedi-data-lake.s3.amazonaws.com/pvdaq/csv/systems.csv') );
And in DuckDB’s SQL dialect you don’t explicitly need the “SELECT *” or the read_csv() function, so this could be abbreviated to:
FROM ( SUMMARIZE FROM 'https://oedi-data-lake.s3.amazonaws.com/pvdaq/csv/systems.csv' );
bwn
Forum|alt.badge.img+26
  • November 3, 2024
Have you exposed the Attributes on the Workspace?
SELECT *” gives no clues to SQLExecutor as to what Workspace Attribute Names to create for generated Workspace Features.  This will need to be set in the Attributes to Expose Parameter, or in a downstream AttributeExposer
If you however view the results in Data Inspector you will see on any individual Feature in the Feature Information any unexposed Attribute values.
arnold_bijlsma
Forum|alt.badge.img+14
@oliver.morris : I’m getting the same: no output when using SUMMARIZE, not even unexposed output.
And its sister statement DESCRIBE even gives an error:
arnold_bijlsma
  • December 6, 2024
oliver.morris
  • December 8, 2024
@arnold_bijlsma nice solution, very cool - I think this means I can build a little hub transformer to summarise a whole set of file types super quick!
