Download NDVI index
mr_fme
Forum|alt.badge.img+8
It's possible to use FME Desktop to obtain indices like NDVI from images without downloading them?
Thank´s
hkingsbury
Forum|alt.badge.img+51
  • May 20, 2024
You can directly reference the image url in a reader, but it is going to ‘download’ it regardless, in this case, store it in a temporary location.
It’s also going to be quite a bit slower to read in the data than it would if you were accessing a file on your local machine
caracadrian
Forum|alt.badge.img+23
  • May 21, 2024
I guess if you store your rasters in a database format you could run SQL to get the pixel value for a known point and let the database do the work for you.
For PostGIS ST_Value() would be your choice for a SQL function.
