Hi, I tried to use Directory and File Pathnames and FeatureReader to control workflow, I used Directory and File Pathnames linked to a gdb file, then put a Tester after it, connected passed port to FeatureReader. But it seems that gdb was treated as folder, every file in picture below was passed to FeatureReader, as result all feature were read muti-times instead of one, how can I set parameters right to get what I want? Or else, how can I control workflow if I don't want some gdbs to be read in fmt?
Directory and File Pathnames read gdb
Best answer by takashi
Hi @bobo, actually a File Geodatabase dataset is a set of files contained by a folder whose name ends with ".gdb". You can confiture the PATH reader to read only "*.gdb" by setting its parameters, as in:
