Design File Truncated - assuming end-of-file message
  • Apr 8, 2013 9:36 PM UTC
  • 5 replies
  • 87 views
I am reading Microstation V7 DGN files (Framme graphics files) in my workspace.  I have noticed that a large percentage of the files are receiving a "Design File Truncated - assuming end-of-file" warning message in the error log.  I have looked at one of the design files using Bentleys EDG and there were some bad eleements listed.  I repaired the DGN file using EDG and ran the repaired DGN file though my workspace.  I'm still receiving the "Design File Truncated - assuming end-of-file" warning message in the error log.  What exactly is this message trying to tell me?
  • Apr 8, 2013 10:24 PM UTC
which version of FME is this? The relevant part of the log would also help, if you could post it.
For what it's worth, we have been using FME 2012 SP4 to process a lot of large-ish dwg files (around 10-40MB each), but I have never seen this message before.
David
  • Apr 9, 2013 11:13 AM UTC
David,
Sorry about that.  I am using FME2013 (20121119 - Build 13233 - WIN32) Desktop.  Here is the section from the log file wth the warning message.
2013-04-08 17:23:25|   2.6|  0.9|WARN  |Design File Truncated -- assuming end-of-file
2013-04-08 17:23:25|   2.6|  0.0|INFORM|Finished reading 2D IGDS design file `D:\\fme_files\\GasTestDGNs\\Man\\tst\\m050480d00.dgn'
2013-04-08 17:23:25|   2.6|  0.0|STATS |READER_PIPELINE IGDS_1::f_0(SamplingFactory): Sampled 1496 of 1496 feature(s)
2013-04-08 17:23:25|   2.6|  0.0|INFORM|Emptying factory pipeline
2013-04-08 17:23:25|   2.6|  0.0|STATS |IGDS_1 Merger(TeeFactory): Cloned 1496 input feature(s) into 1496 output feature(s)
2013-04-08 17:23:25|   2.6|  0.0|STATS |Unexpected Input Remover(TestFactory): Tested 1496 input feature(s) -- 1496 feature(s) passed and 0 feature(s) failed
2013-04-08 17:23:25|   2.6|  0.0|STATS |Unexpected Input Remover Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2013-04-08 17:23:25|   2.6|  0.0|STATS |Source -> Generic(TeeFactory): Cloned 1496 input feature(s) into 1496 output feature(s)
2013-04-08 17:23:25|   2.6|  0.0|STATS |xrefs Feature Counter -1 45(TeeFactory): Cloned 1496 input feature(s) into 1496 output feature(s)
Let me know if you need any other information.
Thanks,
Steve
  • Apr 9, 2013 11:45 AM UTC
what happens if you open the files using the Bentley viewer? Also, you could consider upgrading to FME2013 Service Pack 1 to see if that makes a difference.
If the Bentley viewer works and FME2013 SP1 still doesn't, I would suggest you send an example file and a description of the problems to Safe support so that they can look into it.
David
  • Apr 9, 2013 12:40 PM UTC
David,
File looks to dispaly correctly in Microstation.  I will try and get FME 2013 SP1 loaded and see if it makes a difference.
Thanks,
Steve
davideagle
Forum|alt.badge.img+21
  • Apr 9, 2013 5:23 PM UTC
Just as a supplementary comment, I have recently seen a lot of these and the common trait that all the files shared was that they contained no features. They were tiles that were exported from a FRAMME system where there happened to be no data but the export still produced an export DGN file with a full schema.
