DateTimeConverter - FME Server
  • Jan 9, 2018 4:06 PM UTC
  • 103 views
surbhi
I am using the DateTimeConverter in a workbench to convert date and time from an Oracle database to an ArcGIS Online feature service. The autodetect feature works in the workbench and the translation is successful. However, when I upload the workbench to the server, the DateTimeConverter is unable to autodetect the date/time value from the input and the translation fails. Has anyone faced and resolved this situation?
Best answer by takashi
Hi @surbhi, I think datetime values read from an Oracle database table can be treated fine with the auto-detect mode usually, but exceptionally, if the datetime field stored <null>, the DateTimeConverter would reject it and cause translation failure. Firstly check if there could be null datetime.
gio
Forum|alt.badge.img+15
  • Jan 9, 2018 4:51 PM UTC
There are many situations where autodetect fails.
Just enter the input format is advised.
  • Jan 10, 2018 7:24 AM UTC
surbhi
  • Jan 10, 2018 5:29 PM UTC
Thanks, that worked!
