Creating a file geodaabase API
  • Dec 1, 2015 3:44 PM UTC
  • 56 views
So I am trying to read from a database and then take only the data I need and create and write to a file geodatabase. When I try the file geodatabase api writer all I have to select a .gdb file. Is it possible to just create it as well in FME so I can just tell FME to save to a certain folder where I want these GBD files at.
Best answer by erik_jan
In the writer you can type the name of the File geodatabase. If it does not exist FME will create it.
davideagle
Forum|alt.badge.img+21
  • Dec 1, 2015 4:01 PM UTC
You can specify a File Geodatabase to write to or you can filter off features based on some attribute and then in the Navigator 'Fanout Dataset' and select a fanout attribute to redirect features to specific Geodatabases based on the attribute tag. See attached none2filegdb.fmw. Perhaps that helps.
  • Dec 1, 2015 4:16 PM UTC
I am looking at it, so I have my FME workbench set to do all the processing of the data and get rid of what I dont want. But when I use the File Geodatabase API writer it keeps asking me to find a .gdb file to save to. Is their a way to just send it to a folder called Info and let the writer create .gdb? I guess that is what I am asking.
erik_jan
Forum|alt.badge.img+26
  • Dec 1, 2015 5:25 PM UTC
