Convert georeferenced PNG to TIF
  • Apr 9, 2019 2:17 PM UTC
  • 216 views
Hi all,
I have several PNG-files along with separate georeferenced PGW-files. How can I somehow import those to FME desktop and convert to a format compatible with Google Earth?
What I want is to make this map an overlay in Google Earth. I also have the possibility of downloading the maps in in GML (.xml), ESRI shapefile, or Mapinfo MIF/MID. Whatever works best. I just want to import to Google Earth somehow.
I'm completely new to map modelling and FME so please give a really simple solution ^^
Thanks,
Ruben
thomas_g
Forum|alt.badge.img+13
  • Apr 9, 2019 2:28 PM UTC
Use a PNG-Reader and convert it to a KMZ-file using a KML-Writer. It's important that you name your output-file with a kmz-suffix eg. map.kmz.
