conversion shapefile in IFC format
geomax
Forum|alt.badge.img+3
Hello,
I am trying to convert an shapefile in IFC format, never did before.
What I did is to connect the reader for shp format to a writer for IFC format but the result is empty.
Please, can you explain me the setting to use or the procedure to perform this conversion?
Thanks
nielsgerrits
Forum|alt.badge.img+54
Please see the article AutoCAD to IFC Conversion Example. This and other articles can be found in the Knowledge Base, a good starting point when learning something new.
geomax
  • March 18, 2024
Hello @nielsgerrits ,
thanks for your reply.
I have seen the Cad IFC article but is for CAD, I have to convert shapefile.
I don’t have knowledge and experience on this kind of conversion and data, honestly. Do you think that can I follow the same process explained on the article?
Thaks a lot.
nielsgerrits
Thaks a lot.
I have no experience in IFC either, but if I need to learn a new format, this is how I start (the articles / documentation). I love to work from working examples, so if the data and workbench from the article work, then you can edit the workspace and change the input, to you shapefile.
