CityGML from shapefile
  • Oct 18, 2017 4:24 PM UTC
  • 99 views
Hello,
I have a shapefile that consists of roof, walls and ground in a buildings model. Each surface has it's own ID ('UUID_BYGGN') assigned to it together with building part ('MSLINK2').
I have a workspace where I read in all the features and sort the surface based on attribute ('IGDS_LEV_N') which tells if it's a roof, wall or ground. After this I assign the attributes 'gml_id' and 'gml_parent_id' to each surface but something is wrong in the workspace. I get error message:
CityGML Writer: Found a cycle. The ids of the elements which created this path were `GML_01861c27-7df2-4021-bd4b-300c3b496991,GML_01861c27-7df2-4021-bd4b-300c3b496991_1,GML_01861c27-7df2-4021-bd4b-300c3b496991'.
CityGML Writer: While determining the CityGML element heirarchy (based on the gml_id and gml_parent_id attributes) a cycle was detected. Cyclic features can't be serialized into a CityGML Document.
A fatal error has occurred. Check the logfile above for details.
Can anyone help me with why this cycle beahaviour occurs? I guess it has to do with the way I assign my UUID:s to the attributes 'gml_id' and 'gml_parent_id' but I can't seem to figure out why!
I am also rather new to FME so that might be a reason why I am having problems also. Thank you :)
daveatsafe
Forum|alt.badge.img+24
  • Oct 19, 2017 11:08 PM UTC
Hi @carolineivarsso,
In your workspace, the non-Wall output from the FilterOutWalls transformer goes to both the BuildingPart and Roof geometry sections. The BuildingParts are given a gml_parent_id from the UUID_BYGGN value and a gml_id from UUID_BYGGN + MSLINK2.
The Roof geometries are given a gml_parent_id of UUID_BYGGN + MSLINK2, which will make them the children of the BuildingPart features, but they are also given a gml_id of UUID_BYGGN, which makes them the parents of the BuildingParts. Hence the circular reference.
Please add a value to the end of the Roof geometry gml_id to prevent them from being the BuildingPart parents.
Hi @DaveAtSafe,
Thank you for the reply! However it doesn't seem to solve my problem... Is still get them same error message:
Did I enter the value at the wrong transformer? I added to modified workspace again.
prio1-esrishape2citygml-ci-2.fmw
daveatsafe
  • Oct 20, 2017 4:08 PM UTC
It looks like you may have the same issue in the Wall geometry. You may also want to check the Base geometry as well - I can't tell just from the workspace.
