changing coordinates of a .LAS file
  • Jul 10, 2014 10:06 AM UTC
  • 104 views
Hey guys,
this is the first time i have used FME, i have been reading some files and watching the Youtube viedos,
i am sure this will be an easy question for you guy!
i am trying to convert the coordinates from the nationalgrid to are localgrid
i have an Autocad script file that have move and scale commend in it,
MOVE ALL  0,0,0 -346000,211000,0
SCALE ALL  0,0,0 1.000410669
but when i use the offsetter command and scale command with these values, Then coordinateExtractor and Logger to view the Coordinates, they dont match
are you guys able to point out a rookie mistake,
cheers
gio
Forum|alt.badge.img+15
  • Jul 10, 2014 11:41 AM UTC
If u scale with 0,0 as scalecentre then it depends on order u execute those commands. Where the objects end up.
If u use centerpoint of object, then its about accuracy. But should be close.
  • Jul 10, 2014 12:58 PM UTC
Thanykou for your reply,
accuracy is not need 100%, how would i go about using the centre point of the object to offset and scale from?
i did the order as in the script
cheers
