Change postgres schema of a reader
  • November 10, 2018
  • 22 views
My question is quite simple but I don't find the solution:
Is it possible to change the schema of a postgres reader, and even the table name ?
This field is disabled when I try to edit the reader (see below).
The only solution I found is to recreate the reader.
Thanks for any answer.
Christian
Best answer by takashi
Hi, by default, you cannot edit the schema (table name, field names, field data types) shown in a reader feature type, but here's an option to allow you to edit them.
Workbench menu: Tools > FME Options
  • November 10, 2018
Hi, looks your screenshot cannot be accessed for some reason. Could you please re-post that?
  • November 10, 2018
Indeed, strange...
Here it is.
  • November 10, 2018
  • November 11, 2018
Oh, that was so simple ! Many thanks (once again) Takashi !
