Can I create a steel frame using AECOsims structural design tool and then export a beam schedule to excel?
  • Nov 8, 2017 7:26 PM UTC
  • 38 views
xiaomengatsafe
Forum|alt.badge.img+11
Hi @stylestom95, I'm guessing that you wanted to use FME to transform the Beam Schedule data into Excel? I'm not that familiar with the format produced by the AECOsim Building Designer tool. But it's likely that the beam schedule information is stored in AEC objects that FME can not read. So, you might need to first export the data you need into a format that FME can read, then we can help with the transformation into Excel. Here is a list of format that we are able to read.
You are certainly more than welcome to test it with our Free Trial. And if you want to see the native support of these AEC objects, please feel free to make your idea heard on our Idea page. Thank you!
