bytea::text sqlCreator differs from Pgadmin
We store a large number of files in a Bytea type as base64 ecoded strings in our database. If i use the pgAdmin to retrieve the data as Text it works fine.
If you excecute the statement below in PgAdmin you get a different result then when you run it in sqlCreator to a Postgres database.
How do i setup FME to get the same results as PgAdmin?
What am i missing here?
select ('\\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'::bytea)::text as test
  • March 4, 2019
FME does not know what to do with a bytea sequence, you'll have to cast it to something else before FME gets to it.
Have you tried something like:
select encode(('\x5545734...141'::bytea), 'base64'as test
If it works as intended, it should be possible to use a BinaryDecoder set to "Base64" to decode the binary.
  • March 5, 2019
Thanks for your response, but i had already tried this. The string i put into the bytea is already encoded to base64 and looks like (when i inspect when inserting it into our database)
'UEsDBBQAAAAIAGNzKk55pjtIWQAAAHsAAAAKAAAAMXJlY2VwLnJjcCXFywmAMBRE0b1gD1OBvPyeSTVBVNyoAUFRq3ckDGfufmAfthl3Hks58NQM15JfwVS2vJ5YT0OWHHkKpNRTpNQ2gugTjBrvAmzSKALpNIZkDSwEqrw65/98UEsBAj8AFAAAAAgAY3MqTnmmO0hZAAAAewAAAAoAJAAAAAAAAAAgAAAAAAAAADFyZWNlcC5yY3AKACAAAAAAAAEAGADIVDgt6KjUARvYNC3oqNQBG9g0Leio1AFQSwUGAAAAAAEAAQBcAAAAgQAAAAAA'
and when i use your solution i get a different string. (probably double encoded)
The problem is that i expect to get the same result from Postgres (pgadmin) aswel with SqlExecutor.
And I found the problem. Appearantly Postgres has a bytea ouput setting that isn't used by FME sqlExecutor. So i added :
set bytea_output = 'escape';
select calculation_point_content::text, calculation_point_content_text from am_calculation_point_sets
where calculation_point_set_code = '1recep'
And now i get the desired results.
