Basic question: How to extract nodes from polys ?
  • Oct 29, 2013 1:13 PM UTC
  • 170 views
This simple task has been stumped. I'm trying to extract 3D nodes from 3D polylines and 3D polygons, to be stored as point features in a separate dataset..
I've tried TopologyBuilder, GeometryExtractor and a handful of other transformers, but I can't seem to find the right combo.
I'm sure it's quite simple, but I do need advice on this.
Cheers.
Lars
Best answer by david_r
if your question is how to convert all polygon vertices into points, try the Chopper with "maximum vertices" set to 1.
David
  • Oct 29, 2013 1:42 PM UTC
David
  • Oct 29, 2013 1:57 PM UTC
Btw, if the result isn't as expected, consider trying a GeometryCoercer with "geometry type" = "fme_line" before the Chopper.
David
  • Oct 29, 2013 2:13 PM UTC
Spot on David :-)
I knew it was as simple as that.
I appended a GeometryFilter, outputting only POINT, and it worked.
Cheers.
gio
Forum|alt.badge.img+15
  • Oct 29, 2013 3:30 PM UTC
...or an intersector and keep the nodes
