Hi, Im trying to Convert a DFX file to a GDB. The CAD file is a repesntation of a Piping System. The conversion runs successfully but pipes that run vertically (along x axis) loose their shape length.
For the Reader in the format attribute tab: autocad_color, autocad_entity, autocad_layer, fme_attrib_info{}.field_value are checked.
I'm using FME Desktop 2014, AutoCAD 2013, ArcGIS/ArcScene 10.1
The DFX is 2007 Format
Â
