associate subtext to the heading text
  • Sep 12, 2019 11:02 AM UTC
  • 6 replies
  • 88 views
Hi
So I have a text document and I need to parse into specific headings and then extract that heading and all the sub text. The issue is the subtext is lettered. Is there a regex syntax that will continue to extraxt until it finds a new match? any ideas?
Im using string searcher and have managed to get all this data as seperate lines, just not sure if its easier to try and find a way to put the data back together or if theres a more efficient way to parse
Current using syntax: chicken{1}\\s|(.
Example: I need every line that starts with "chicken" the chickens name and all the numbered lines below
TEXT TEXT TEXT TEXT TEXT TEXT TEXT TEXT
Chicken: Rene
(1) lays three eggs a day
(2) escaped two weeks ago
Chicken: Stacey
(1) etc
and so on
Best answer by ebygomm
If you have a single text document, could you read the text file as one feature, then use an attribute splitter with Chicken as your delimiter, then explode the list
Forum|alt.badge.img+54
  • Sep 12, 2019 12:28 PM UTC
  • Sep 12, 2019 12:37 PM UTC
I've never used this transformer. It doesnt seem to be doing anything diffrent. I get the same list I was getting with string searcher. Can you provide an example of how I would set this up Please and thank you.
Edit: I see the issue, the original text is already broken up by line, so it not a single document. I aggregated it into a single document but the splitter still does not work, the way I was expecting
gio
Forum|alt.badge.img+15
  • Sep 12, 2019 1:15 PM UTC
@tmtech
You can use Stringsearcher (possibly in combination with a Variable Setter/Retriever).
Regexp for the chickens (If the data is a string with newlines: basically has only one "end of line" ).
Chicken: (\\w+)(?=\\n)
For all lines with "chicken properties"
(?=\\()\\((\\d)\\)+.*(?:(?=\\n)|$)
  • Sep 12, 2019 1:24 PM UTC
chicken.fmw
  • Sep 12, 2019 1:38 PM UTC
I was doing it properly, I just wasnt exploding the list, adding the exploder let me see the results, this worked thank you!!
gio
  • Sep 12, 2019 2:32 PM UTC
Concerning (?=\\()\\((\\d)\\)+.*(?:(?=\\n)|$)
In the regexp i use a escape character (bold) on the bracket.
(?=\\() The "\\" is used as an escape character for the "("
This seems not to be processed in the stringsearcher.
In Rubular:
Perfect!
However...
When i enter it in the attribute creator using a tcl regexp. It tells us this:
The regexp is ok but escaping the opening bracket seems to confuse fme engine(?)
