ArcGIS Portal Feature Service Date Where Queries Confusion
peteratqfes
I have a host feature layer on Portal 10.8.1 and want to use a date where query.
Documentation from ESRI point to being able to use Intervals in the query but when I try to use in the Portal Feature Service reader the server returns a 400 error.
https://www.esri.com/arcgis-blog/products/api-rest/data-management/querying-feature-services-date-time-queries/
It appears you can only use a proportion of a day in the FME query. The help page FME desktop points you to from ESRI isn't exactly that informative.
https://doc.arcgis.com/en/arcgis-online/reference/sql-agol.htm
Is this a Portal versus AGOL difference?
This works:
"created_date" >= CURRENT_TIMESTAMP() - 0.015
This doesn't:
"created_date" >= CURRENT_TIMESTAMP - INTERVAL '15' MINUTE
If anyone can point me to a definitive page with the documentation for where datetime queries for hosted Portal feature layers.... 😀
Thanks,
Peter
Best answer by rahulsharma
Short demo with a portal
rahulsharma
Forum|alt.badge.img+10
Hi @Anastasia Petrenko​
Appears to be working as expected without any issues.
Tested against an ArcGIS Portal 10.9.1 (Enterprise) with hosted feature service.
"firediscoverydatetime">= CURRENT_TIMESTAMP - INTERVAL '360' HOUR
"firediscoverydatetime">= CURRENT_TIMESTAMP - INTERVAL '1440' MINUTE
"firediscoverydatetime">= CURRENT_TIMESTAMP - 10
rahulsharma
