AppearanceSetter changing GeometryTraits
  • October 30, 2020
  • 44 views
Hello everyone. I am working with citygml modeling and I am facing some problems with appearanceSetter.
I have a workspace similar to the con terra that I used as a base.
Originally everything is fine but when I put an appearance setter before the roofSurface writer (ground or wall too). The geometry traits previously set are automatically modified by the FME. In the image below is the original output.
traits_originalAnd in this the output with the appearanceSetter.
traits_fme_genapp_uriThe geometry trait created for polygons was moved to linearRing and a new one was created for polygons.
The file is normally opened by the Data Inspector, however, when running Val3dity to perform the validation, the xlink is broken, as it must point to a polygon.
EDITED: I forgot to mention that to reproduce the situation above i placed a appearanceRemover just after the reader to remove the original appearance of input data.
Does anyone know how to fix it?
Thank you in advance for your help.
Mcdonnell
babint
Participant
  • Participant
  • April 29, 2024
Actually @mamaieron ,
I am also facing the same please let us help the community people.
In appearance setter I am facing the issue.
