Alter elevation value in a DWG
I would like to add 100m to all the elevation values in a DWG file. However, how do I do this if the file contains polylines? I want to add 100m to all the vertices along the polyline.
I am using FME2016 Desktop.
Thanks,
  • March 13, 2017
You can use a 3DForcer before the writer.
  • March 13, 2017
Hi, the Offsetter (Cartesian Coordinate Mode) might help you, if you want to add a certain amount to existing z-coordinate for every vertex.
  • March 13, 2017
Thanks Takashi, the Offsetter works exactly as I would like it.
  • March 13, 2017
Also, is there anyway to extract the vertex X Y and Z values along a line in some sort of list?
jdh
Forum|alt.badge.img+28
  • March 13, 2017
CoordinateExtractor in mode All Coordinates
