adding multiple child elements xml to existing xml or replace value if tag exists from excel
tnarladni
Forum|alt.badge.img+16
I have an excel spreadsheet with 3 columns (featureclass, tag, summary). I want to update the metadata.xml file that corresponding to the featureclass. These xml files are embedded in a column in an sde table gdb_items. I'm able to extract the xml, but I don't know how to add xml elements. I have seen the xmlUpdater which works but only when that tag exists in the xml. Also, the "tag" field in the excel is a list of tags separated by commas. I need to create multiple <keyword> tags, one for each item. Here's my workspace so far.
shows the xml without the existing "summary" and "tag" <idPrup> <searchKeys> with child nodes <keyword>, respectively
shows xml with those nodes (lines 80 to 86)
Best answer by takashi
Hi @tnarladni, I think you can use the XMLUpdater in conjunction with an AttributeSplitter. This is a simplified example.
Source XML Document
<?xml version="1.0"?>
<metadata>
    <Esri />
    <dataIdInfo>
        <envirDesc />
        <dataExt />
        <dataExt />
        <dataChar />
    </dataIdInfo>
    <mdLang />
    <distInfo />
</metadata>
Values to Add
Summary: A simplified example describing how to update a metadata XML document
Tags: Centerline, Route, Series, PODS
Workflow
Result
<?xml version="1.0" encoding="UTF-8"?>
<metadata>
	<Esri/>
	<dataIdInfo>
		<envirDesc/>
		<dataExt/>
		<dataExt/>
		<idPrup>A simplified example describing how to update a metadata XML document</idPrup>
		<searchKeys>
			<keyword>Centerline</keyword>
			<keyword>Route</keyword>
			<keyword>Series</keyword>
			<keyword>PODS</keyword>
		</searchKeys>
		<dataChar/>
	</dataIdInfo>
	<mdLang/>
	<distInfo/>
</metadata>
  • August 4, 2017
Source XML Document
<metadata>
    <Esri />
    <dataIdInfo>
        <envirDesc />
        <dataExt />
        <dataExt />
        <dataChar />
    </dataIdInfo>
    <mdLang />
    <distInfo />
</metadata>
Values to Add
Workflow
Result
<metadata>
	<Esri/>
	<dataIdInfo>
		<envirDesc/>
		<dataExt/>
		<dataExt/>
		<searchKeys>
		</searchKeys>
		<dataChar/>
	</dataIdInfo>
	<mdLang/>
	<distInfo/>
</metadata>
  • August 4, 2017
Source XML Document
<metadata>
    <Esri />
    <dataIdInfo>
        <envirDesc />
        <dataExt />
        <dataExt />
        <dataChar />
    </dataIdInfo>
    <mdLang />
    <distInfo />
</metadata>
Values to Add
Workflow
Result
<metadata>
	<Esri/>
	<dataIdInfo>
		<envirDesc/>
		<dataExt/>
		<dataExt/>
		<searchKeys>
		</searchKeys>
		<dataChar/>
	</dataIdInfo>
	<mdLang/>
	<distInfo/>
</metadata>
In addition, if you would use this XQuery expression to create the <searchKey>  element, the AttributeSplitter could be removed from the workflow.
<searchKeys>{
for $tag in fn:tokenize(fme:get-attribute("Tags"), '\s*,\s*')
return <keyword>{$tag}</keyword>
}</searchKeys>
  • August 4, 2017
Source XML Document
<metadata>
    <Esri />
    <dataIdInfo>
        <envirDesc />
        <dataExt />
        <dataExt />
        <dataChar />
    </dataIdInfo>
    <mdLang />
    <distInfo />
</metadata>
Values to Add
Workflow
Result
<metadata>
	<Esri/>
	<dataIdInfo>
		<envirDesc/>
		<dataExt/>
		<dataExt/>
		<searchKeys>
		</searchKeys>
		<dataChar/>
	</dataIdInfo>
	<mdLang/>
	<distInfo/>
</metadata>
See also this workspace example: xmlupdater-insert-nodes-example.fmw (FME 2017.0.1.1)
deanatsafe
  • August 4, 2017
Hi @tnarladni,
XMLUpdater is a good approach to use when updating existing XML documents. However, if you find the XQuery scripting a bit tricky to customize for your needs, the other option is a hybrid approach. Instead of the searchKeys{} loop, you could use an XMLTemplater to create an XML fragment of the searchKeys element with the keyword sub-elements. You will likely need to create a sub-template and feed it with one record for each sub element. Then use XMLUpdater to insert the searchKeys xml fragment. For more working with XMLTemplater see: https://knowledge.safe.com/articles/30940/xml-writing-with-xmltemplater.html
tnarladni
  • August 17, 2017
xml-update
Thank you gentlemen @takashi and @DeanAtSafe for your help. I used both of the answers to get really close to the end result. I am still having trouble with checking whether the node exists before doing something to it. The xmlUpdater assumes the <idPurp> and <searhKeys> nodes do not exist. I have the xmlxQueryUpdater in here, but not sure if that's even the way to go. Here's my latest workspace. could you take a look and help me? Thanks!
tnarladni
  • August 17, 2017
tnarladni
  • August 18, 2017
tnarladni wrote:
xml-update
@takashi and @DeanAtSafe, I updated my workspace and used tester to look for the <idPurp> text which is only used for the purpose I'm using it for (updating the summary of the dataset in its metadata). So I guess it would make sense to use this transformer? Let me know if you think I should use something else?
Also, I used XMLFormatter to make the xml pretty and it's adding the header <?xml version="1.0"...> to my xml. In the other XML transformers, there's an option to add the header or not, but not the XMLFormatter. Is there a way to remove that?
  • August 18, 2017
tnarladni wrote:
xml-update
I'm not sure what the major issue. If you want to determine if the XML document "geodb_metadata_string" contains "//dataIdInfo/idPurp" element, a possible way is to use an XMLXQueryExtractor with this setting.
The "_result" attribute of the feature output from the XMLXQueryExtractor will have "true" if the element exists, otherwise "false".
XQuery Expression:
fn:exists(//dataIdInfo/idPurp)
tnarladni
  • August 18, 2017
XQuery Expression:
Thanks @takashi. I would like to use the xml transformers more so I will use that instead of the tester. Do you have a suggestion for the other issue I'm having? that XMLFormatter is adding the header node?
  • August 18, 2017
tnarladni wrote:
xml-update
What is other issue do you have?
deanatsafe
  • August 18, 2017
tnarladni wrote:
xml-update
@tnarladni you can remove the XML header by using a StringReplacer to replace '<?xml version="1.0" encoding="UTF-8"?> with "". I understand your suggestion that it would make sense to have this as an option on the XMLFormatter to make this easier. I'll add an enhancement request to that effect.
stephstedman
Participant
Forum|alt.badge.img+4
  • Participant
  • January 15, 2020
@tnarladni are you able to reupload your 2nd update-metadata.fmw
I've got a similar query and wanted to look at what you'd done, but the link no longer appears to work
Thanks
tnarladni
  • January 15, 2020
Thanks
Hey @stephstedman
Unfortunately, I'm not working for that company anymore, so I don't have access to that script. I'll reach out to an ex-colleague to see if she's able to upload it.
stephstedman
Participant
  • Participant
  • January 16, 2020
tnarladni wrote:
Hey @stephstedman
Thanks very much
  • August 31, 2021
Hi, I am also trying to insert sibling nodes to an xml attribute. Can you share the above mentioned fmw. Thx.
kailinatsafe
Forum|alt.badge.img+21
Hello @sdave​ , xmlupdater-insert-nodes-example.fmw should be available for download now. Best, Kailin.
