Adding in a custom coordinate system
  • Apr 24, 2024 4:56 AM UTC
  • 208 views
xingfu07
Hi All,
I’ve tried to add in a custom coordinate system and it just doesn’t work. I’ve restarted my computer twice and the co ordinate system won’t come up in the csmap reprojector.
I would love to use the online webform that has been created, but I am unsure at which username and password is required to log-in. My usual FME doesn’t work.
I’ve created a file in the FME folder in documents and edited both coordinate files in the reprojector folder. This is what I have written below:
# COORDINATE_SYSTEM_DEF PerthCoastalGrid1994     \\
#      PROJ TM                                  \\
#      UNIT METER                               \\
#      SOURCE "spatialreference.org"            \\
#      DT_NAME GDA94                            \\
#      EL_NAME GRS1980                           \\
#      DESC_NM "Perth Coastal Grid 1994"        \\
#      GROUP AUSNZ                              \\
#      PARM1 115.8166666666667                  \\
#      ORG_LAT 0                                \\
#      X_OFF 500000                            \\
#      Y_OFF 3800000                           \\
jkr_wrk
Forum|alt.badge.img+37
  • Apr 24, 2024 6:47 AM UTC
Are you sure the lines should start with: # ?
Looks to me like it's commented out as an example. Could you try removing them?
xingfu07
  • Apr 24, 2024 11:02 PM UTC
Thanks for replying. Tried that and it didn’t work.
steveatsafe
Forum|alt.badge.img+16
@xingfu07 I’m late to the party and I’m sure you have found the solution by now… but in case you have not or others have the same question...
     PROJ TM                                  \
     UNIT METER                               \
     DT_NAME GDA94                            \
     EL_NAME GRS1980                           \
     GROUP AUSNZ                              \
     ORG_LAT 0                                \
     X_OFF 500000                            \
     Y_OFF 3800000
Note the changes:
  1. No comments (#)
  2. No double \\ just singles \
  3. Last line has no \
Ensure to restart FME after saving the changes.
arnold_bijlsma
     PROJ TM                                  \
     UNIT METER                               \
     DT_NAME GDA94                            \
     EL_NAME GRS1980                           \
     GROUP AUSNZ                              \
     ORG_LAT 0                                \
     X_OFF 500000                            \
     Y_OFF 3800000
Note the changes:
  1. No comments (#)
And remove colon (:) between the keyword and value, which you get if you follow this instruction:
“In the properties window of the coordinate system, copy the text under "Coordinate System Parameters", and paste in a text editor.”
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Form/Workbench/coordinate_sys_custom_about.htm
