Add row(s) above header in Excel
djmcdermott
I would like to add a new row containing some descriptive information from a seperate stream above header row in an excel spreadsheet.
Thanks
David McDermott
Best answer by takashi
Hi @djmcdermott, a possible way is to write data records starting with a specific row using a FeatureWriter, and then write (insert) descriptive rows starting with the first row in the same sheet using another Excel writer. You can control starting row through the Start Row parameter in the Excel writer feature type. For example, assuming that the number of descriptive rows is three,
FeatureWriter (Excel Writer / Feature Type) Parameters
  • Overwrite Existing File: Yes
  • Output Field Names: Yes
  • Use Attribute Names As Column Positions: No
  • Start Position | Start Row: 4 (= 3 + 1)
Excel Writer / Feature Type Parameters
  • Overwrite Existing File: No
  • Output Field Names: No
  • Use Attribute Names As Column Positions: Yes
  • Start Position | Start Row: 1
Forum|alt.badge.img+22
  • June 20, 2017
gio
Forum|alt.badge.img+15
  • June 20, 2017
Excel reader has a xlsx_row_id attribute.
Read the excel, increase xlsx_row_id by 1.
Create your row to be inserted on top, give it number 0 and sort.
Write to excel.
djmcdermott
  • June 21, 2017
Thanks @takashi. Shame there isn't a more elegant way in the writer itself.
  • June 21, 2017
If you will write the header (field names row) as well as the descriptive rows, this workflow is also possible, since you can specify the row number (1-based sequential number) for each feature via the Row Number Attribute optionally. I don't know if this is more elegant...
bernarddinon
Hi @Takashi
Your answer help me a lot to solve : https://knowledge.safe.com/questions/112230/how-to-define-some-values-in-excel-header-with-att.html
Thank you
