Add New Attribute to Dynamic Properties in writer
  • Jun 13, 2013 5:19 AM UTC
  • 7 replies
  • 150 views
rudy_v
I've worked through all the various schema mapper examples but could not find one on how to add a new attribute to the writer schema.
I would like to read the source and add a attribute called
CadLayer as varchar(30) with value of autocad_layer from the source autocad drawing
The source can have various object data attribute fields
one example i have in source dwg
MCCID_INT     integer
MCCID_STR   char  255
NAME               char  255
i also would like to change them to char 50
I'm writing to arcsde 10.0 feature class
tx
Rudy
  • Jun 13, 2013 6:48 AM UTC
it usually works if you just add and modify your attributes manually on the writer.
David
rudy_v
  • Jun 13, 2013 6:57 AM UTC
I forgot to add my writer is dynamic properties, read from source schema and create writer schema
Rudy
fmelizard
Forum|alt.badge.img+22
  • Jun 13, 2013 7:09 AM UTC
In the case of adding, you just have to add the attribute in the writer, as David points out, in case of modifying in a dynamic translation it wont work since the schema is defined by the resource or dataset used.
The new SP2 provides better dynamic possibilities, but I dont have yet any experience with it.
Itay
  • Jun 13, 2013 7:21 AM UTC
Hi Rudy,
you can define the writer schema as an external table. Refer to "Dynamic Schema Examples".
Takashi
rudy_v
  • Jun 13, 2013 7:32 AM UTC
Hi Takashi,
thanks for answer, but i don't want to read writer schema from table, i'm reading it from the source, and just want to add new attribute to the writer
see my question - i want to add an attribute called CadLayer as  a char(30) field type and then mapped its value with autocad_layer.
I'm using schema mapper but cannot get it to work
Rudy
Hey Rudy,
maybe it will work without the SchemaMapper.
1. You set up you dynamic schema
2. Expose the autocad_layer attribute if necessary in the reader feature type  properties
3. Use an AttributeCopier to copy the values form autocad_layer to your new attribute CadLayer
4. In your writer feature type create a new user attribute called CadLayer with varchar(30) (if necessary connect the attribute from the AttributeCopier to the Writer Attribute you created).
Hope that works,
best regards,
Stefan
  • Jun 13, 2013 9:56 AM UTC
I understood your requirement, but I think a new attribute cannot be added to the writer schema as long as you use the source schema for the writer.   I often use a common table for both of the SchemaMapper and  the writer dynamic schema. The table has 6 fields: Feature Type + New Attribute Name *+ Old Attribute Name * Attribute Data Type + Geometry Type + Attribute Sequence + (* for the SchemaMapper, + for the writer)   And when I need to add new attributes to the output features, I do that before the SchemaMapper (exposing autocad_layer in your case).
I think this trick is convenient to manage attribute mapping and dynamic writer schema consistently. Although this doesn't fit to your requirement exactly, if you are using a SchemaMapper, it might be worth considering.
Takashi
