Writing to existing SQL Server table
Hello. I have a workbench that reads an XML and splits it into attributes with their values (with one spatial attribute). I am trying to write this data to an existing, empty SQL Server table. If I set the writer to create a new table, it runs fine, but I can't seem to get it to populate my existing table. The workspace runs, and passes with warnings, but when I go to my SQL Server table it is still empty. Any ideas?
My writer is configured as follows:
Feature operation: Insert
Table Handling: Use existing
The translation log claims that all of my features have been written, and the data inspector shows them fine, but it just won't populate my table.
Thanks!
  • June 26, 2015
the first warning i get is this:
WARN |MS SQL Server (Spatial) Writer: Could not commit row locally. Provider error 'Description: Unspecified error'. Try turning off 'Bulk Insert'
  • June 27, 2015
Firstly check whether the every feature follows constraints of the existing table.
e.g. "not null", "primary key", "foreign key", "unique", "check".
Takashi
todd_davis
Forum|alt.badge.img+22
  • November 9, 2016
Just had this. The error message didn't provide much detail into what was going on but was able to narrow it down. In my case it was a smallint (not Null) field in SQL that we were trying to pass '' (eg blank) to. @SteveAtSafe
arnold_bijlsma
Forum|alt.badge.img+14
Just had the same issue. Turned out I had a value > 1000 when the field was set as numeric 5.2. Changed it to numeric 7.2, and the error message no longer occurred.
jkatarski
Participant
  • Participant
  • August 23, 2024
In my case it was because there was a slight difference in schema (capitalisation only) so the attributes weren’t actually mapped, even though I’d linked the Reader and Writer. On closer inspection, I was being told this by the tiny gold arrow on the Reader, and the tiny red arrow on the Writer.
bo
Forum|alt.badge.img+10
  • November 6, 2024
I may have encountered another case.  Here is the warning log
When I manually constructed and ran the SQL insert statement against the database, I got this error:
Msg 6522, Level 16, State 1, Line 4
A .NET Framework error occurred during execution of user-defined routine or aggregate "geometry":
System.FormatException: 24114: The label %i\x00\x00\x01\x07\x in the input well-known text (WKT) is not valid. Valid labels are POINT, LINESTRING, POLYGON, MULTIPOINT, MULTILINESTRING, MULTIPOLYGON, GEOMETRYCOLLECTION, CIRCULARSTRING, COMPOUNDCURVE, CURVEPOLYGON and FULLGLOBE (geography Data Type only).
   at Microsoft.SqlServer.Types.OpenGisTypes.ParseLabel(String input)
   at Microsoft.SqlServer.Types.WellKnownTextReader.ParseTaggedText(OpenGisType type)
   at Microsoft.SqlServer.Types.WellKnownTextReader.Read(OpenGisType type, Int32 srid)
   at Microsoft.SqlServer.Types.SqlGeometry.GeometryFromText(OpenGisType type, SqlChars text, Int32 srid)
   at Microsoft.SqlServer.Types.SqlGeometry.Parse(SqlString s)
The statement has been terminated.
Here is the image from SQL Log-
I am using the “Microsoft SQL Server Spatial” driver (format) and I was under the impression that it would generate the SQL-flabored WKB for storage.  Not sure why it is ask for WKT.  Perhaps I need to encode the WKB in FME before writing to the target table?
Thanks!
