When will we be able to update FME Hub custom transformers to FME 2024?
caracadrian
Forum|alt.badge.img+23
Just update eterra3.ancpi.roGeometryFetcher. Updated all transformers to 2024, created a workaround for Tiler not completing a Conditional Value for $Parameter Contains/Begins with, created a test suite, uploaded .fmx and .fmw to the Hub.
This is the Test Suite Failure Log:
2024-03-12 20:33:35|   0.0|  0.0|INFORM|Current FME version: FME 2023.2.2.0 (20240205 - Build 23781 - linux-x64)
2024-03-12 20:33:35|   0.0|  0.0|INFORM|System Time: 20240312203336 UTC
2024-03-12 20:33:35|   0.0|  0.0|WARN  |Workspace was last saved in FME version: FME 2024.0.0.0 (20240304 - Build 24187 - WIN64)
Can’t run 2024.0 workspace on 2023.2.2.
Please fix this!
By the way, in case safers missed it: Something is wrong with the Conditional Value in transformers that only have Arithmetic Editor (for transformers that have both Text and Arithmetic Editor it appears to works)
Be the first to reply!
