webhook message content {message} keep reverting back to the string "Message Content" with no curly brackets. FME Flow Hosted 2023.1
  • Oct 18, 2023 8:49 PM UTC
  • 50 views
badgerseatfrog1
  1. click into the input variable Text Editor and dbl click the Webhook/message Content and this is the result:
  2. image
  3.
  4. Click OK then APPLY
  5. Click back into the Text Editor and it's reverted back to this. I can't get it to stick with it's curly brackets:
  6. image
So as you could imagine any actions in the workbench downstream from this complains it's not a valid jsonimagehelp!
this is the parameter published from Flow in_json:
imageloosely following this from 2019
https://community.safe.com/s/article/Emailing-a-Survey123-Report-using-FME-Server
badgerseatfrog1
another_examplechanges into this
changes_to_thisthis doesn't seem like it should be doing this.
