run a workspace in response to an incoming email
  • Sep 10, 2020 2:33 PM UTC
  • 81 views
HI
I m trying to experiment "run a workspace in response to an incoming email, i have a problem with the IMAP configuration.
although i use the template (for gmail for instance) and enter my email address and password)
my automation do not work
i have this message :
809009 : pascal.mortz@gmail.com : Failed to connect to email server. Please check IMAP settings, and ensure IMAP is enabled for the email account. Error message: [AUTHENTICATIONFAILED] Invalid credentials (Failure)
this is my configuration :
Capture
I authorize IMAP Access in gmail account parameters.
Mays someone help ?
Regards
Hi @pascalmortz​ ,
Gmail sometimes blocks FME Server as it treats it as an unknown device. Therefore if authentication is failing there are two options:
  1. Generate an App Password, you'll need to enable two step verification to do this.
  2. Add FME to your Gmail trusted apps by turning on 'less secure app access'
I have tried the two solutions
  1. I have generated an App password, after two-step validation of my Gmal account.
  2. So i changed the password in the automation/Email (Imap) task.
  3. i authorized IMAP access in my Gmail account, of course.
  4. but when i run the autmation, i still encounter problems :
809009 : pascal.mortz@gmail.com : Failed to connect to email server. Please check IMAP settings, and ensure IMAP is enabled for the email account. Error message: [ALERT] Application-specific password required: https://support.google.com/accounts/answer/185833 (Failure)
I try the second solution :  'less secure app access'
in this case, tha automation is running well, no problem of authentification.
but when I send a mail with a ZIP attached, noting happened in the LOG file.
i dont understand.
